Kinetic Woodworking
  • Kinetic Woodworking
    I found this on another site:
    I'll stick with ornaments!
    Fred
    I have seen that site before, very remarkable!
      Those are really amazing sculptures. Too bad he doesn't want to sell plans.
      • Sandy Oaks
        Teach - Learn
        by Sandy Oaks
        This gallery has 2 photos.
        Today, 12:13 PM
      • Sandy Oaks
        by Sandy Oaks
        Today, 11:22 AM
        Today, 09:54 AM
        Today, 09:51 AM
        Today, 09:42 AM
