wood filler
  • wood filler
    I stack cut several ornaments ,I used a backer board but I still
    had some tear out on the walnut and mahogany. I went to Lowes
    and found some wood filler for these two woods mentioned. The
    walnut color did ok,but the mahogany turned it more of a dark red
    than I liked.My question is can you do something to lighten the wood filler
    color? I am afraid if I try to dig out the filler I will only tear the wood more.
    I wished now I had not put wood filler on and just seen what it would have
    looked like after sanding and finishing.
    Bill
    Delta P-20
    Unfortunately I don't know of any way to lighten the filler.
    I like to save the sawdust from projects it is super fine and can be made into filler with urethane,
    If I am cutting two species of wood at once the blend of sawdusts masks the cracks beautifully.
    Heck if I get enough sawdust maybe I will make MDF
      Not sure what type you got. If you got the pencils it is easy to just go over them with whatever color you want. I like those alot. You can blend colors easily. If it is the small little jars. Try using some acetone to take the color out. I am not sure why you are worried about the back though. Seems trivial.
      John T.
      • planeur
        My puffin coming home....
        by planeur
        My first creation in intarsia , with a gift from my sister of that little puffin in stained glass. After couple of tests , I created this frame , as in my blue heron, and put the puffin leaving the water and waves, between rocks and with a look to his smiling rock mounster, on a beautiful sunset....
        Today, 11:16 AM
      • vgraf
        Reply to What do you think?
        by vgraf
        I have a VacuFlo system for my house. It might have enough suction for a small table saw but not for the large cabinet makers saw like you have.
        Like the others have said, your Walvac might work fine for smaller tools, especially for a hand sander.
        The VacuFlo actually uses...
        Today, 02:20 AM
      • vgraf
        Reply to My lucky day!
        by vgraf
        I got my second shot last week here at the Eisenhower Med Center in Palm Springs. I am 82 and in their system and was contacted by them to come in for my first shot. At the completion of that shot I was given my appt. for the second shot.
        Like yours Rolf they were really organized both times....
        Today, 01:56 AM
      • dgman
        Reply to Another Mid-Michigan Scroller
        by dgman
        Great looking work Jeff! Welcome to the forum from Southern California!
        Yesterday, 11:57 PM
      • dgman
        by dgman
        My wife and I got our second shot two weeks ago, we’re done!
        Yesterday, 11:50 PM
