i was wondering how many of you scrollers sign your work and, if you do, what do you use? thanks.
Signing your work
I use an ultra fine point sharpie between coats of finish.
KevinKevin
Scrollsaw Patterns Online
I have always signed my scroll saw work because when I'm done I am very proud of my accomplishments. On larger projects I have a large stamp that I heat with a torch. On my smaller projects I use a woodburning tool with a fine writers tip. I burn in the following: Hand Crafted By: My name, my addresss, my phone number and the date. I also lay one of the blades that I used in the project below my name and then put a generous bead of Contact cement over it so that the new owner of the plaque or project can see partially how the item was made. (everyone always comment on how small my blades are that I used.)
DickPractice Doesn't Make Perfect! Perfect Practice Makes Perfect!
Signing your work
I started signing my intarsia work a few years ago. I desigend a Logo and reversed the image and printed several copies onto one sheet . Made copies on a Xerox copier. And when I need one it cut it from the sheet.
Then I sand the backing board very smooth, then tape one edge of the cutout logo and use a small iron to re-heat the ink. ( Press firmly ) The ink transfers right onto the wood surface and you can lift it off (gently, leaving the tapeed portion attached to be sure all of the logo 'printed' to the wood. After the logo is applied I let the surface cool and then apply a finish. The ink will NOT run or bleed.Jack Labor - Elmwood Intarsia
I use a ultra fine Sharpie and put my name and the year like 06 and not the whole 2006 . I sometimes don't sign my work-depending on what it is -like a cross but I have one lady that insists that I sign what ever it is she gets.why I don't know but I figure that if it has my name on it then it is the best I can do..maybe it does make me try harder to be perfect on my pieces but heck -- thats just me.
Sharon
Reply to Bible standby Jim McDonaldA quick Google search for fretwork book stands showed pattern on Pinterest. Might be worth a look.
Today, 12:39 PM -
Reply to Spring Issueby Quartz43I agree that with fret work the grey areas may be useful but not needed for Intarsia and some others. It would not be difficult to use grey for some patterns and just lines on others.
Another thing to note is that not many have the ability, software or equipment to stitch patterns back...-
Channel: Publisher Feedback
Today, 11:02 AM -
Reply to YoraHome Laser w/CNC Engraver/Routerby RolfThis is only my opinion.
Hi Linda, My first reaction is it looks good, and my new toy craving started to twitch, but I thing it will be very limiting very quickly.
It is a small engraving machine and if that is what you want and need maybe OK. You are limited to 1/8 shank...-
Today, 10:25 AM -
Reply to Peanuts #1by millwabI still have some puzzle blades from Ben Fink. Once I run out of them I’ll have to ask Denny what he recommends for a substitute....
Channel: Scroll Saw Puzzles
Today, 09:56 AM -
Reply to Spring Issueby Rolf[QUOTE=Quartz43;n873079]No doubt, the large patterns are a real challenge. Not many have a large size printer. Going out and finding a place to do large scans and prints is problematic with the virus and many of us are older.
I wish they would not print the patterns with the grey. Pure...-
Today, 09:47 AM -
