There are several good fonts for scrolling. I like to use one that is a brass stencil from Plaid Products. It is called Jazz. I got mine at WalMart.
I like it because you only drill one hole per letter.
If you have a word processor or desktop publishing program which will allow you to kern fonts (adjust the spacing between letters) you can do some great text work by printing out your own patterns.
You can identify the font you are looking for with this great site Identifont
While you are at the Identifont site, you can look for symbols or pictures which are stored as fonts. Also great for scrolling patterns.
Your computer may have come with free software like MS Works, or something. Usually, there is a menu bar across the top, and if you select Tools, a selection window opens and you can select Fonts or something similar.
When the Fonts window opens, look for the checkbox for Outline. Click on the various options which allows you to select the way the font prints out. Sometimes, you have to select the words, change the font color to have a dark shape outline, and then change the 'fill' color to white.
The problem is this, there are three types of lettering:
1- free standing. No backing board, but the letters are attached to each other by glue or cut that way.
2- Bold, but glued to a backing board, like most street address. This allows the letters spacing with a word to look more normal.
3- Recessed, negitive lettering. A solid wood, and the lettering is removed. Usually very dramitic, but looks bad on a wall.
(There is a 4th, but we won't go into stencil fonts)
You could also google for free fonts. But expect to spend a long Saturday afternoon searching thru all the hits you will get.
BTW: there is a whole lot of words that come from the printing business like Kerning the Font as previously mentioned. Don't let the lingo get under your skin. It is just trade talk that expresses how the letters relate to each other, how the words relate to each other, and how the paragraphs relate to each other as physically displayed on the page.
Don't forget my fave, bevel-cut raised (or recessed) lettering. No need for stencil-style connections to interior spaces or for gluing back little pieces to a backer.
No need for an apology, you provide too much good information to let this small item be meaningful. I was only wanting to be sure because, when I was traveling recently and visiting craft stores (we only have one in our town) I was asking for Jive and no one had it.
all windows operating systems are just choke full of fonts that might be used all over the computer. so many that one can gain space by deleting alot of them. In windowsXP home edition I think I counted 429 diff font styles. you can print these samples and then do what ya want with'um. try this.
click on start
then settings
then control panel
then look for the icon that says Fonts
then dbl on that
that should bring them all up but you will need to dblclk on each one to view/print. it would be possible to print and make size to suit and even make your own stencil.
I agree with you Mark, I am constantly changing or adapting my patterns to suit my taste or the size of the wood that is available to me. Thinking about electronic versions of the patterns, that would be great. But very hard to control. It amazes me how many people have no scruples about sharing....
Bruce I just looked up the Pegas blade and the Flying Dutchman puzzle blade.
So the Flying Dutchman is a bit thinner , not sure it would make a significant difference. Three teeth per...
Project size 6 x 5,5 inches
Perhaps, we could hear from Fox. Maybe they could try some things and see if it makes things better. Or, they can just keep doing the things the same way.
I personally like the patterns to be printed at the artist's intended size if at all possible. Let me decide to reduce or enlarge. If I don't have the equipment to make a copy at 100%, that's my problem not the publishers. We all have our own...
