Most of us are aware that a blade will cut more aggressively on one side than the other.
With that in mind, when cutting an inside cut on a piece of fretwork, do you prefer cutting in a clock wise or counter clockwise direction?
Do you have more control cutting one way than another?
Do you alternate directions depending on what you are cutting?
If you are using crown tooth blades can you tell which way the blade is inserted by the action of the cut?
