are there any other scrollers from the maritimes here? i'm curious as to where you buy your wood. no one around here seems to supply wood in 1/8, 1/4 and 1/2 thickness and i don't have a bandsaw or planer. i'm getting tired of working with baltic birch ply. thanks.
Canadian Scrollers
Originally posted by jttheclockmanNot sure if that is a camera effect but check the sky out. That is awesome.
here's another pic. i was actually leaving when i saw that view so i quicky stopped the car and snapped the above pic.
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
by cwmageeCarole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
Today, 08:40 AM -
by RolfThat is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
Today, 07:28 AM -
