Well I have asked about this software a few times and no one is familiar with it.
I broke down and spent the $20 and now I have it.
The software does exactly what it says it does and is quick and easy to use.
As for using it as a scrollsaw pattern there are a few points I came across.
The pattern generated is exceptional, as you are making the stencil you even get a preview of the "floating" parts that would fall out of a pattern. Then you can modify the stencil to stop this.
You can set the brightness up to make different stencils from the same picture.
There is one drawback, the image that is produced has reference dots to poke through the stencil to mark the pumpkin. If you can see past the dots you can use the software.
I have contacted the manufacturer to see if they can modify it for use on Fretwork.
Lets hope they want to fill that void in scrolling software.
