Reduce or Enlarge Your Patterns
  • Reduce or Enlarge Your Patterns
    If you need to figure out the percentage for changing the size of your patterns. Here is a site online that has a good calculator.
    Thanks for the link!
    Phil
      If you don't have a computer available.. make a 3x5 note card with this formula..
      ND= New Dimension; OD= Old Dimension (original)
      (OD / ND) x 100 = % to plug into copier
      eg: if you have a 12" tall original and want it to fit a 6" board, the numbers would calculate out as:
      (12 / 6 ) x 100 = 50%
      Hope that helps
      Bill, Healdsburg, CA
      www.picturetrail.com/chips
        Welcome
        Smokenque:
        I noticed you are new to this site, and seem to be reading some older posts.
        So Welcome. I hope you enjoy your visits.
        Would be so kind as to go over to the Welcome Members area and post a few words about your self? You know, type of saw, if you like fret work, portrait work, intarsia, so forth. Take a photo of some of your work and post tgem on the 'scoller gallery' section. If you are shy about posting your work, say so, we do understand.
        Phil
          Rolf,
          Are you ok Rolf?
          Yesterday, 05:43 PM
        • Jim McDonald
          by Jim McDonald
          Yesterday, 09:10 AM
          Yesterday, 07:43 AM
        • evilbadger
          by evilbadger
          Yesterday, 06:40 AM
          09-28-2023, 08:41 PM
