I am scrolling a 12 X 12 Silhouette of a wolf and would appreciate any advice on cutting, expecially when getting to the end to avoid breakout. I am currently using a 26" Hawk with a ply insert and a no. 5 spiral blade at a speed of about 500. I am not using the hold down foot. I am using 1/4 birch ply.
Silhouette
You can do a lot to eliminate breakout on plywood by switching to a blade with reverse teeth.
Will we get a chance to see your work when it's finished? I'm a sucker for anything to do with wolves.
Splinter
I like to run my saw a little faster than 500 strokes/min. it seems less prone to catch the piece and jerk it around. I like Mikes flying dutchman blades for this kind of stuff, I use really fine blades #1 with lots of teeth. I'm not an expert on this stuff though and I just play around a lot. Good Luck Guy.
Well there MRCSW you are using one of the finest saws on the market so it should cut itself out. Just kidding. I too have that saw. As far as suggestions not sure what you are looking for but as suggested that speed is too slow for sure. You always want to try to cut at a fast speed that you can control. There is nothing wrong with the spiral blades if that is what you are used to. If not this piece may not be the one to experiment with because of the size. I never could get the hang of them so I do not use them. I would use a #5 double skip tooth revers blade. These are my favorites. Of course they are Mike's Flying Dutchman blades the best on the market. They are the Penguin Silver reverse blades.. The thing I find with spiral blades it will leave more fuzzies on the back . You can try the packing tape trick where you put clear packing tape under the print for easier removale and cutting easier. but you should have no problem with 1/4" and I would even stack at least another on there. This will help in controling the blade better. The thinner you cut a piece the less control you have. Plus you get two for the price of one.John T.
Reply to YoraHome Laser w/CNC Engraver/Routerby RolfTony have fun, There is a great lightburn forum on face book also for Orture I would assume. What size did you get?
Linda, With the laser engraver I just jumped in and then realized I had bought something that was very limiting and started to research after the fact. I know better, but...-
Today, 10:02 AM -
Reply to Spring Issueby will8989Bruce wishes I was less challenging.
Channel: Publisher Feedback
Today, 09:42 AM -
Reply to What is it?by will8989Good guesses, but no. It’s very useful and “outside the box.”
Today, 09:39 AM -
Reply to What is it?by RolfMy first thought is to hold the small paint bottles, but the holes are not symmetrically spaced....
Today, 09:31 AM -
Reply to Spring Issueby RolfI am of the older crowd, LOL , I was blessed with a father, old world German tool maker and a Mom that turned into a techno junky. She got into computers in her mid 70's and digital embroidery, started digitized music that she played using computer software. she was a seamstress, by profession.
Today, 09:29 AM -
