A customer asked me about having a soundhole on a mountain dulcimer in the shape of a deer or moose. That sounded fine, but when I started poking at the idea with a sharp stick, I realized that just a hole in the shape of a deer silhouette would lose a lot of detail. I wanted to be able to get the detail in, but then where would the outline come from? It can't be too fragile, as this is a musical instrument to be strummed.
I came across a pattern book called North Amwerican Wildlife Patterns by Lora Irish (published by guess who?), which contained patterns intended to be standalone outlines with internal details. I took one of these patterns, spray-glued it to a small piece of 1/8-inch walnut, which I then spray-glued to a piece of 1/8-inch butternut. I bevel-cut the outline at nine degrees so that the walnut dropped down into the the butternut, glued the walnut shape into the butternut hole, and then cut the internal details with the blade square to the table.
The result is below, if I managed to get it attached correctly. I used a scrap piece of butternut for this demo; the soundboard of the dulcimer will be of a similar piece.
