Horse and Girl
  • Horse and Girl
    This is a Jim Blume pattern I finished cutting last weekend and was able to put the finishing touches on it today. It is cut from 1/4 maple plywood using Pegas 2/0 and #1 spiral blades. The backer board is 1/4 pine. The front was finished using Minwax Natural and then glued to the black backer board. The entire project received 4 coats of gloss spray poly with light sanding between each coat. This was a fun project and the first time I used spiral blades.
    Rodney, very nice. Perfect frame and matt to highlight it.
      Beautiful work Rodney - you certainly have mastery over those blades! Very nicely framed and finished to set the subject off.
      Congratulations.
      Jim in Mexico
      - Albert Einstein
