4th (finished)
  • 4th (finished)
    Took the better part of 3 days but it is now done.
    Brian in the Four Corners
    Excellent Outstanding!
      Keep up the great work!
      cwmagee
      aka Fibber
      Producer of fancy firewood​
      • Don in Brooklin On
        Reply to wipe on poly and tack cloth
        by Don in Brooklin On
        I use wipe on poly quite often and I apply 2 thin coats before sanding with 220 or 320. I wipe with a lint free. Someone told me not to use tack cloth as you can leave behind a wee bit of beeswax witch could cause issues later on.
        I make sure that the surface is dry and not tacky before...
        Yesterday, 05:41 AM
      • dwssr2
        by dwssr2
        Question, when sanding polyurethane in between coats, using a tack cloth, is it ok to wipe on poly while the project seems tacky or should a person wait a few hours to let it dry?
        How necessary is it to sand between coats of polyurethane? I am sure people have a lot of different opinions and...
        04-24-2019, 05:58 PM
      • tgiro01
        Reply to Do you know what this Is?
        by tgiro01
        Betty asked: "Where does the responsibility of the maker of an item end and the responsibility of the purchaser begin? My sealife puzzle is purchased by older people due to its complexity but - if they leave it laying around and a child gets a part and chokes, is that my responsibility or theirs?"...
        04-24-2019, 12:20 PM
      • RJweb
        by RJweb
        The problem now a days everyone is sue happy, no matter who’s at fault, RJ...
        04-24-2019, 10:03 AM
        Don’t forget to carry insurance if you sell a lot. It’s a necessary expense and a good "silent" partner and hope it stays that way. Where does the responsibility of the maker of an item end and the responsibility of the purchaser begin? My sealife puzzle is purchased by older people due...
        04-24-2019, 08:44 AM
