First Portrait project
  • First Portrait project
    This is a portrait I made of my two youngest grandkids. This is my first attempt at making a pattern for fretwork. Kerry for your great instructions.
    Tim
    Excellent on both counts Tim. Kerry you make a good teacher.
    kevin/pitbull.
      Very nicely done.Jerry
      Don't worry be scrolling
        Very good, thats a picture you can do blackmail when they get older.
        Chuck D
        Jean De La Bruyere...
        l
          Thank you Tim and Pitbull. It's nice to see the techniques I outlined coming though in the work of others.
          Excellent job Tim.
          Check me out on the web:
          http://www.kerrysworld.com
          • tgiro01
            Old Tool - Reborn
            by tgiro01
            With all these new tool stories, I was working on and old one. About 9 years ago, I built a router table. Then, before it was finished, I had to start using it. And I have used it over the years. A couple of months ago, While I was contemplating cleaning, I looked at the machine and decided to finish...
            Today, 03:24 PM
            I do remember that 2011 Wow, you were gutsy building that then, CNC was just coming into the home environment. Are you still using the one you built?
            Today, 10:23 AM
            Jim that is why there are now CD's available for past issues. To me a copier/scanner and printer are a necessary part of my tool inventory. JMO...
            Today, 10:19 AM
          • Jimern
            by Jimern
            I dropped my subscription long ago, so maybe I should not chime in, but I dropped it mostly due to the pattern pull out.
            But the result is that if I cut a pattern to scan, I have also cut the parts of...
            Today, 07:55 AM
          • Quartz43
            by Quartz43
            +1 on NC Scroller's suggestions. I would add that on appropriate patterns stop using the grey as it would make it easier to copy.
            It says a lot if Fox Publishing does not comment on an issue like this. Even if they said they are aware that people have concerns and are looking into it...
            Yesterday, 08:15 PM
