"Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
That's smashing, Dale . Where did you get the pattern? I know someone who likes parrots and who might dig out their sadly disused saw if they could cut something like that.
Gill
Thank you everyone. The pattern is one i made up from a drawing.as for how quack I do them..once pattern is stuck on the wood, and without interruptions, that would take me about 2 hours roughly.I am a slow cutter. The cardinal one floating around on here took me a lot longer, lots of tricky cuts. The hardest part..those webbed feet! Dale
Never thought doing it that way. I made top piece out of 1/4” plywood to place on top of my Hegner table. I use carpet tape to hold in place. I only use it for my extra large baskets but I like your idea. Thanks!...
