I have done a fretwork saw before but with the detail this one had, I thought the only way to get all the detail in (with clean lines) was to use a #1 spiral blade. Never had any luck with one before, but then the 'patience' wasn't there yet either. Stock is 1/4" poplar with a dark color. Handles are red oak also 1/4" thick. Any comments would be appreciated. Would you have used a spiral blade too?
First attempt with a spiral blade
Pop
Delta 16" 40-530
Ryobi 16" VS
"Never be afraid to try something new. Remember it was amateurs that built the ARK but Professionals that built the Titanic!" -
Great looking saw Pop, I have several saws posted in the gallery but haven't done that one yet. My hat is off to you for doing that with spirals. I can't get the hang of those blades they seem to have a mind of their own for me and the mind wanders. Steve -
The saw looks great, although I feel a lighter piece of wood would make the design stand out better.Personally I wouldnt have used a spiral on that, but could if i needed to. I am partial to the smooth crisp cut from a flat blade, so I use spirals on some things with at least 2 batrillion holes, and no places where tolerances are real important.Looks great though! DaleDale w/ yella sawsComment
looks good. spirals aren't all that bad in my opinion, work nicer on a4 oak ply though. my opinion
crftyComment
I really like the contrasting collors and the brass rivets really set it off.
Nice job. I would also use the spirals.
Was that the natural color of the poplar?Rolf
And the Long Island Scrollsaw AssociationComment
That cutting looks great Pop, though I think I would have preferred a lighter coloured blade too ..
Just curious - those who use spirals - how do you get out of the habit of spinning the wood when you get to a turn??? My couple of attempts with spirals have been pretty awful ...Ian
Scrolling with a Dewalt 788Comment
Originally posted by PuzzledMooseThat cutting looks great Pop, though I think I would have preferred a lighter coloured blade too ..
Just curious - those who use spirals - how do you get out of the habit of spinning the wood when you get to a turn??? My couple of attempts with spirals have been pretty awful ...Daryl S. Walters Psycotic scroller with a DeWalt 788Comment
absolutely stunning, one can only stand back and admire stuff like this..Comment
[QUOTE=PuzzledMoose]
Just curious - those who use spirals - how do you get out of the habit of spinning the wood when you get to a turn??? QUOTE]
As an advid spiral user I always question how others do it with flat blades, when Barry (Bearfretworks) came out to the house last week we had a good laugh over my weak flat blade skills. But I am working to relearn.Todd
Hawk G4, Dremel 1800
Quando Omni Flunkus Moritati
Nicely done.I have cut a couple of the saws and used maple for the blade and yes I used spiral blades. The brass rivets sure do make a big difference as to the finnished look compared to dowels. How did you find cutting the teeth to be the same length width etc? I had made a saw clock from a pattern from Wood Magazine a couple years ago and used the jig for cutting teeth to cut the teeth for the latest saw.
I cut the Wolf drinking water pattern from Wildwood last year with straight blades but if I cut any more it will be with spirals .Never used to like them but now have cut a few of Jeff Z patterns and have no problems.Last edited by B Smith; 01-04-2007, 01:55 PM.Smitty
Dewalt 788Comment
Originally posted by RolfI really like the contrasting collors and the brass rivets really set it off.
The first saw I did was in maple and I used a straight blade. I was worried I wouldn't be able to spin the blade clean enough to get the detail in the church and trees... so I used a #1 spiral.
I must admit, with my foot pedal making starting and stoping what I'm doing so easy, I still would stop and turn the work so when I was cutting (or trying to cut) straight lines, I'd be pushing into the blade straight on.
Thanks for the input. It's ALWAYS appreciated.Pop
Delta 16" 40-530
Ryobi 16" VS
"Never be afraid to try something new. Remember it was amateurs that built the ARK but Professionals that built the Titanic!"Comment
OH... I almost forgot. The brass rivets are actually screws. I get them at the local ACE hardware. I first used them to hold the wooden bows to the top irons of my Model A. What you see is the threaded end of the "rivet". The other side of the saw handle is the wide screw heads. They work great!Pop
Delta 16" 40-530
Ryobi 16" VS
Originally posted by B SmithNicely done.I have cut a couple of the saws and used maple for the blade and yes I used spiral blades. The brass rivets sure do make a big difference as to the finnished look compared to dowels. How did you find cutting the teeth to be the same length width etc? I had made a saw clock from a pattern from Wood Magazine a couple years ago and used the jig for cutting teeth to cut the teeth for the latest saw.
I cut the Wolf drinking water pattern from Wildwood last year with straight blades but if I cut any more it will be with spirals .Never used to like them but now have cut a few of Jeff Z patterns and have no problems.Pop
Delta 16" 40-530
Ryobi 16" VS
Reply to About ornament exchangeby Jim McDonaldDave, I will participate. Thanks for doing this again.
Yesterday, 09:10 AM -
Reply to Testing this blower motorby RolfWithout the complete schematic it is hard to know what is correct.
That said, it is a multispeed blower that obviously has a controller board. That board varies the power to the motor. By doing what you did you bypassed that. You put power across the low and high windings. If any thing connecting...-
Yesterday, 07:43 AM -
Reply to Testing this blower motorby evilbadgerIf he connected to red and black and the motor spun wouldn't that indicate the motor is grounded? Without connecting the white the circuit isn't complete and the motor should not spin.
Yesterday, 06:40 AM -
Reply to Testing this blower motorby cwmageeThe reason for the smoke is incorrect wiring, posible melted insulation between motor windings and motor frame.
You mentioned connecting power to the red & and black wire. Did you do anything with White wire? Per the lable on the motor the black wire is high the Red is low. White common...-
09-28-2023, 08:41 PM -
