Did these for xmas this year paper is about the same thickness as card paper stack of 30 at once hope you all like Jerry
angel & faith cross paper cuts
What ever made you think to use stacked paper? What type of stock did you use.. and glue? I can imagine using different colors stacked to get a deeper looking cutout area.... Hm-m-m-m-m-m-m-m. Neat concept. Forgive me if this is a normal thing. I'm new to scrolling.Pop
Delta 16" 40-530
Ryobi 16" VS
"Never be afraid to try something new. Remember it was amateurs that built the ARK but Professionals that built the Titanic!"
paper stock
The paper I use is about the same as poster board for thickness.White on both sides. To do this I use 1/8 " ply elmers glue to hold the pattern to the ply ,Brad nails on four corners or as needed and drill holes with a 60 drill bit. 2/0 blade stack 20 - 30 depending on the cut.If you can do fret work you can do this .It opens the window for all kinds of things to use these for from sun catchers to xmas cards made home made or just stuff them into the cards that you send also scrap booking or wedding decorations work
Jerry
Jerry... I no sooner got off the site the other night and started thinking of stuff to do with layered paper. I took some colored poster board and glued it up to about 3/16 thickness and plan on trying a 3-d popout style card for the grandson's BD this new year. Keep your finger's crossed and thanks for the inspiration.Pop
Delta 16" 40-530
Ryobi 16" VS
Paper cut outs
When I glue the pattern to the 1/8 board I use elmers spray glue that way I get a wooden cut out also .To get the paper off the board I use a heat gun ( Hair dryer will work also) that loosene the paper from the wood and than clean the remaining glue off and you have another cut out so two wooden cutouts and a stack of paper not bad for 10 minutes work
Jerry
I like the idea of stack-cutting paper. If the paper has an adhesive backing, it could be used for all sorts of decorative projects.
oaoer cutting
In answer to Graceman I use 1/8 board on top and bottom that way I have coup[le of good wooden scrolls also
Now for gill paper i use is aboput the thickness of card stock no glue on back but now i have to look for some of that thanks for the idea some more time away from saw lol
Reply to My lucky day!by RolfWhen I see the long lines of people waiting outside all over, I realize just how lucky we are....
Today, 09:50 AM -
by RolfI tend to be a bit scattered when it comes to projects, I get bored and move to something else mid stream. It seems to be getting worse with age,
Any way I decided to tune up both of my saws, the EX 16 and my Hawk G4-26. I thought I had the EX perfectly square to the table until I cut...-
Today, 09:47 AM -
Reply to Darkening oakby NC ScrollerIs this too dark?
Ebonizing Wood - FineWoodworking-
Today, 09:19 AM -
Reply to My lucky day!by NC ScrollerGreat news. I know from personal experience getting the vaccine has been a great uplift to me. It gives a new hope that the worst is truly behind us. In the US we did not have a choice in most cases. You got whatever you got. My wife and I both had the Pfizer one and had minimal issues like: arm...
Today, 09:12 AM -
by Jim McDonaldSometime back, there was some discussion about darkening oak. I have used the search and found something about fuming with ammonia, but I think there was another method using vinegar.
I have a suspicion it may have been lost in the software change.
Any guidance appreciated.-
Today, 09:10 AM -
