College wall plaques
  • College wall plaques
    Hello all,
    I made these for a co-worker of mine. She has 2 grandchildren in college. The first is St Joseph's University in Philadelphia and Tuskegee University in Alabama. They are made from 1/8" bass wood with a 1/8" backer. I used a FD-UR #1 blade to cut. As always suggestions and comments are welcome. Thanks for looking.
    Mark
    Proud new owner of an EX-21
    WWW.MGMWOODWORKS.COM
    Nice work! Thanks for sharing and God Bless! Spirithorse
    • Sandy Oaks
      Teach - Learn
      by Sandy Oaks
      This gallery has 2 photos.
      Today, 12:13 PM
    • Sandy Oaks
      by Sandy Oaks
      Today, 11:22 AM
      Today, 09:54 AM
      Today, 09:51 AM
      Today, 09:42 AM
