Alex Fox Pattern of Basket C16. I enlarged the pattern by 30% to fit 1/4" x 10" square Baltic Birch plywood. Cut on the Pegas Scroll Saw using #1 MGT blades. Pilot holes drilled with #68 HSS twist drill bits. Sanded with a Mac Mop and finished with two coats spray Lacquer Clear Gloss. Comments welcome.
Alex Fox Basket C16
I like this design. nice cut and assembly. Do you assemble upside down.?Rolf
Originally posted by planeur View PostI was wondering about the assembling , but it is OK now ! wood glue on all 13 rows ?
What peoples do with that basket ,is it fragile ?
Bravo, lot of fines cuttings
planeurDenny
ArtCrafters in Dayton, TN
Reply to Wood lampshadeby RolfReally nice work! I personally prefer a Semi gloss or Satin finish. The only time I may use a gloss finish is on some wood turnings.
Today, 07:44 AM -
Reply to Wood lampshadeby planeurHere is somes of my inserts , in ebony , and I put to reinforce at the back of the bird (chickadee ) a MDF with real wood on each side , total of .096" , because the cuttings was very delicates ! Still have some sanding on a couple of them!
Not finish yet of cutting inserts , I have...-
Today, 07:03 AM -
