An Alex Fox pattern he lists as C12. I used 1/4" Baltic Birch plywood 10" square. Cut on the Pegas scroll saw using Pegas #1 MGT blades. After gluing, two coats of spray Lacquer clear gloss. Comments welcome.
Alex Fox Basket C12
I made that awhile back out of 1/4 cherry. Came out great but drove me crazy gluing up. Of course, that was a short ride!!
Betty
- Likes 1
That is a beauty.! This design with its 7 deg rotation between layers is why I made my alignment jig.Rolf
Originally posted by NC Scroller View PostNice work. I truly admire all the projects that you share and I truly envy the fact that you finish what you start. What is your secret?Denny
ArtCrafters in Dayton, TN
Reply to Miniature Birdhouse Ornamentsby RolfI also enjoy making these. I have also used the profiles to turn some on the lathe. I mostly use a 220 Mac mop I have a 180 for the harder woods and then finish with the 220. I do all sanding before assembly.03-22-2023, 07:08 AM
Inquiring minds want to know.
Karl03-21-2023, 08:15 PM
