Earlier I mentioned that I had found a wood bowl, 13 inches diameter x about 4 1/2 inches deep, at the local Thrift Store. Below are a couple of pictures of the bowl. One is of the bowl as I purchased it and the second is with the pattern I plan to use to saw a design around the top of the bowl. This is the first time I am doing this and I expect there to be a few challenges along the way. I will probably have to drill more than one starting hole in each opening in order to get into the corners of the opening. I also expect to reverse the direction of my blade so the teeth are facing the back of the throat and I will be pulling the bowl towards me as I saw. No doubt it will be slow going. I will keep you updated on my progress and maybe have a video if I can manage it
Garry
Garry
