Making of woodworking project - rose in dome. Project made by scroll saw Pegas CE16. Scroll saw pattern available at https://www.etsy.com/shop/AlexFoxUA alex...
Hi Alex.
after I tried some layered designs myself, and got some experience designing,... You asked what I think, here are some ideas:
First off, as a project, the rose itself looks fantastic. Although the dome with its three layers of frame somehow reminds.me of a jukebox. As a frame however it works, although I personally would make the bottom in the same vein like the sides.
Then for the rose, I love how the veins of the leaves come out. However this is tempered a bit by the fact that both leaves are at the same height, which makes the result look a bit flat. Of I were to improve on the design, I would raise one leaf, preferably the right one, by one level so that there is a little difference of height between them.
The same goes for the rose flower. The top is a bit too wide so it looks flat. I would leave off the left part of the top layer so the top starts with the petal this will draw the attention to the right side and make the left side look a little rounder.
As a last idea, try leaving out the bottom layer so that you can actually see through the glass dome. I used something similar for my sailboat and it works out well. May be it works with this design as well
but that's about all for now.
I have been trying to purge my basement and shop of "stuff". I had enough yesterday and needed a sawdust fix. I cut the compound cut Water bird designed by Diana Thompson and test cut by my friend Joe Pascucci, a fellow club member. I followed his suggestion of using a harder wood, maple....
