Basket - C59
  • Basket - C59
    This is a pattern by Alex Fox and purchased from his Etsy store. It is made from 1/4" solid Cherry approximately 10" square and ends up 3 1/4" high. I used #65 drill bit and FD UR #1 blades. It is finished with two coats of spray Polyurethane Clear Satin. Comments welcome.
    Denny
    ArtCrafters in Dayton, TN
    Beautiful piece, excellent job of cutting, RJ
    Life Begins @ 190 MPH
      Thanks RJ. The difficulty was the glue up.
      Denny
        Very pretty choice of wood for this decorative piece. What type of glue did you use? Any recommendations for someone wanting to try one of these?
        Linda at www.ArtIngrained.com
          Really nice, and I agree that the glue up is the biggest challenge. Especially trying to keep things symmetrical.
            Thanks Linda. I used Titebond 111. Alex Fox has several videos which are well worth viewing.
            Denny
              Thanks Rolf. Starting upside down and gluing top to bottom help keeps the gluing symmetrical.
              Denny
                Nice work! When I finish some of the projects that I have on my shovel, I might take this project on.
                cwmagee
                aka Fibber
                Producer of fancy firewood​
                  Thanks Fibber. It is a fun project.
                  Denny
                    I've had a couple of those shovel ready projects here recently. Not nearly as much fun as making sawdust!
                      Excellent cut - so accurate! I also like choice of wood
                      Alex Fox Patterns
                      https://www.etsy.com/shop/AlexFoxUA
                        Thanks Alex. I enlarged the pattern to fit 10" square stock. Much easier to cut and fit.
                        Denny
