This is one of Alex Fox's designs. I increased the pattern by 25% and did not cut the bottom ring leaving it attached to the ring above. This made it not so fragile. I used 1/4" solid Walnut approximately 10" square. Drilled with #68 bit and cut with FD UR #1 blades. The finish is spray Polyurethane Clear Satin. Comments welcome.
Basket C15
Looks great! The hardest part for me with these bowls is the assembly with no glue squeeze out.
What glue did you use?Rolf
I have some dental tools I bought that I use for squeeze out. I always use titebond 3.Betty
It dries clear but does it take the finish? When I have squeeze out I some times take a piece of sandpaper and sand it off while the finish is still wet. Sometimes you don’t see the glue spot until the finish is applied.Betty
Turned out really nicely! I too get excited and in a hurry sometimes. Can't blame you one bit!Linda at www.ArtIngrained.com
Sometimes I will glue the bowl in 2 ring sections, clean them up when dry then glue the rings together. I also put a glue dot as small as possible. Sometimes I dot the glue with a toothpick. Tite bond 3 is very strong it’s mostly all I use.Betty
Reply to Wood lampshadeby RolfReally nice work! I personally prefer a Semi gloss or Satin finish. The only time I may use a gloss finish is on some wood turnings.
Today, 07:44 AM -
Reply to Wood lampshadeby planeurHere is somes of my inserts , in ebony , and I put to reinforce at the back of the bird (chickadee ) a MDF with real wood on each side , total of .096" , because the cuttings was very delicates ! Still have some sanding on a couple of them!
Not finish yet of cutting inserts , I have...-
Today, 07:03 AM -
