Layered ornament
    Advent wreath
    For one of my good customers. From the fall issue 2016. Cherry and African mahogany. Bruce turned the candle holders as we couldn’t find candles to fit any already made wooden holders. I used the green sparkle unicorn spit over green paint for holly leaves and red for the berries. Yes, I actually...
    Yesterday, 11:39 PM
  • Ennobee
    Reply to 10" long truck.
    by Ennobee
    Looks pretty neat. So it's from a 2x4: 3 in wide, 'bit less then 2 in. high? So how did you get the trunk cut out? You mentioned cutting the sides with a scroll saw, did you slice off two sides and then cut out the middle?...
    Yesterday, 09:46 PM
  • vgraf
    Reply to sanding sealer or shellac
    by vgraf
    I use sanding sealer on baltic birch plywood, pine and birch if I am going to stain them. Without the sanding sealer, the stain will be blotchy. I use the water base sealer from minwax. After it drys I sand to at least 150 grit and often to 220 grit. Wipe it with a tac cloth then apply the masking...
    Yesterday, 08:27 PM
  • Jim Finn
    by Jim Finn
    We, our club, delivered over 900 toys last week to The Salvation Army, Ronald McDonald House, and a local children's hospital. Included were most of these trucks. (I sold a few)
    Yesterday, 07:17 PM
  • NC Scroller
    by NC Scroller
    The real nice thing about using shellac and alcohol mix for ornaments is you only have to wait minutes before you tie in your ribbons and packaging.
    Yesterday, 10:48 AM
