Piano Box
  • Piano Box
    Here is one I made a while back.
    Harry..
    Harry, that is beautiful. It looks so real.
    Denny
    ArtCrafters in Dayton, TN
      Very nice craftsmanship.
        Amazing! How did you do the keys?
          Great job Harry, it looks good in oak. I also like the bench. This looks like the pattern that was in a SSWWC issue, I know that because I did the test cut. It is a John Nelson design. The keys are made like a comb. in two layers, glued together then cut. When I made it I used holly for the keys and wenge for the black ones. For more detail I made slight cuts int he white keys top and front to define them. keys .jpg
            Yes Rolfl that's the way I made the keys, only l painted the Keys
            Didn't have any wedge or Holly. Incidently am I right in thinking Holly is about the whitest wood you can get, is it easily Obtainable In the U.S. rare as rocking horse droppings
            Here.
            Harry.
              "Rare as rocking horse droppings". Never heard that one before, Harry.
              Denny
                Yeah Danny that's the polite way of saying it, can't say what
                It's really calle​​​d not on the Forum.
                Harry
                  It is available but not very common. Aspen is also very white but Holly is the best. My keys have yellowed a bit over the years and look just like ivory now.
                    Wow. Only a 3 letter word, but it says a lot!
                    Linda at www.ArtIngrained.com
                      Thank you Danny Rolfl and Linda for your comments.
                      The piano stools was an extra I put in. I Think the designer
                      Intended it to be a music box but I didn't get that far. I remember now Rolfl did the cutting for the original box
                      A question R olf how did you cut cut the
                      Profile on the piano sides? I wasn't happy
                      With the way I did mine I used a hand fretsaw
                      It turned out a bit messy
                      Harry.
                      Ò
                        That is a good question Harry, I sort of remember that being a bit tricky. I will have to go back to my notes to see if I wrote anything down.
                        Here is what I wrote in my notes. "The most difficult cuts to make were the sides next to the key board. I roughed it out with a copping saw and then used a Dremel to carefully shape up to the line." Now I would probably use my spindle sander to instead of the Dremel.
                        Yours looks just fine in the picture. I will take a new picture of mine as the mahogany I used has gotten very dark.
                          I did much the the same as you Rolfl with the piano sides
                          But I hand sanded to shape. I THINK IT WAS Mentioned a band saw could be used, but after loosing the tip of my thumb
                          To my bandsaw it seemed like sailing to close to the wind, I keep my fingers as far as possible from the blade these days.
                          Harry.
                            I can;t get the idea of rocking horse dropping out of my mind. Looks like I am now going to have to design a rocking horse that poops!
                            Dave
                              Good luck designing a pooping rocking horse Dave You're going to make a fortune when you do.
                              I have every confidence in you, go for it.
                              Harry.
