had to find this as it was packed away for next year
santa with compound deer
by NC ScrollerGlad you got it worked out. Happy endings are always the best. Can you post a picture? It might be helpful to someone else in the future....
Today, 03:44 PM -
Reply to Minor Question About Bowlsby scrollerpeteIf the bowl is not used for wet stuff you can use Titebond glue that dries up invisible. My trick is after applying the glue and I used my bowl press from Carol, after a few minutes, release the press and use a plastic straw cut at an angle to remove the excess glue.
https://www.leevalley.com...Today, 02:08 PM -
by RoyzMGThanks for the comments. I finally designed my own tool that works great.
Today, 01:16 PM -
by RoyzMGI'm just beginning to try my hand at bowls and I've been following Carol Rothman's book on scroll saw bowls. I'm on my second bowl and now understand why you need to sand the inside before attaching the bottom ring. My question deals with gluing the bottom ring. It appears to be very important to...Today, 01:15 PM
Reply to Bigger Projectsby Chance13I have a 20" Delta that I made Judy''s "Hidden Forest" with. Took me all of 9 months of trying to find the right wood,etc.
You could use a 16" saw as you can break down the pattern and pieces into smaller sections.
I won a best of show ribbon with it.
Excuse...-
Channel: Beginners Scroll Saw
Yesterday, 12:57 PM -
