This is my first box. I wanted a fun and geeky box to hold my dice. I knew people had done 6-sided dice so I wanted something different. I cut the pieces to the box on my scroll saw (though any bevel-capable saw would do), then glued together the halves. The two sides are held together by pairs of strong magnets. The numbers are engraved and painted. The box itself is oak.
20 Sided Die Box
Ah D&D fan. Nicely done."Still Montana Mike"
I tried to set the bevel between 20 and 21 degrees. I think the correct angle for a perfectly flush cut would be 20.9-ish, but that's hard to get on my saw, so I did have a little bit of an internal gap for glue to fill.
I applied the numbers by applying a pattern to each triangle with the correct number on it. After cutting, I just used a dremel to cut through the pattern where the ink was for the numbers. I have a terribly unsteady hand so I couldn't have free-handed it and have it turn out half so nice.
Thanks you all for your responses. I sure had fun making it
by John SmithI've used 1/4 and 1/8" blades from different sources with good results. I use carbon fiber blade blocks so I can put the blade in the middle of the blocks. You have to "tune" the blade for your specific saw. Several videos on YouTube on how to tune band saw blades.
If you google...Yesterday, 09:57 PM -
...Yesterday, 07:31 PM -
by John Smiththanks Carole. I used the band saw with a 1/8" blade - not much different than the scroller but I have to use other methods to do the insides of the letters where the band saw can't reach. All the while, WISHING I had a scroll saw. and now, that I've got one, I'll be venturing back into dimensional...07-01-2022, 07:21 PM
by handibunnyVery impressive work, John. I like the tooled leather look, the detailed calligraphy, and especially the rendition of the brushes and other tools that you use for your craft. It will be interesting to see how you incorporate the scroll saw into your work, and the opportunities it provides you.07-01-2022, 06:31 PM
