Well here is my first bowl that actually made it all the way to being finished without ending up in the scrap wood bucket. It's made out of 3/4 pine and went together with just some fine sanding unlike my other attempts.
My First Finished Bowl
Originally posted by KarenC View PostNice bowl! I haven't gotten up the courage to try one myself yet. Was it hard to get the angles right?
And thanks Carole for your help up until now all I had managed to make was fire wood.It's only a mistake if someone saw you do it.
Sweeeeet beans, this is one of many you will make, somehow I just know it. Congrats on sticking with it, and for sharing your photo with us.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Flat wood is really critical to getting the glue-up just right. Stack the rings and check carefully for any spaces before gluing them together. A sheet of 150 grit sandpaper attached to a granite tile is a great surface for getting rid of irregularities. Don't skip this step, even if you have to spend a lot of time on it.
You can always sand the inner and outer faces of your glued up rings, but if there are little gaps between the rings, the bowl will never look great (guess how I know!).
Another tip: if you have some really ugly places on your rings--bad cuts, drill marks, etc., you can often start the sanding process by getting out the worst of the mess before you glue the rings up. Just be sure you have enough wood to do that. If not, just glue it up and make the best of it. I've rescued many bowls that I was sure were hopeless, including some that were good enough to include in the book.
And don't forget to enjoy the ride!
Reply to Question about tilting head sawsby handibunnyIt doesn’t matter whether the saw table tilts or the saw arm tilts. Either can be used for any project cut at an angle, and there’s a learning curve for each.
I actually prefer the tilting table because the blade remains vertical. I find that at really steep angles, like 40 or 45 degrees,...-
Channel: Welcome Members
Today, 02:10 PM -
by will8989This is the tapestry I found in the cedar chest. We can’t identify where the pictures are from. Two among many. I also forgot to mention dad was also in the army Fife and Drum Corps and also played with a big band when he was discharged. Have to find that info....
Today, 12:34 PM -
Reply to Bruce doing greatby will8989What a morning. The therapists were quite pleased with what he could do. He took the wrap off today and he can walk with the walker with very little pain. It’s getting the leg completely straight that is hard to do. It’s when his brother stopped in that things went off rails. Rolf, we are talking...
Today, 12:19 PM -
Reply to Question about tilting head sawsby Sandy OaksIf you are referring to 3D Compound cutting, the blade is 90 degrees to the table and not tilted. I use the tilting head for things like inlays and Carole's bowls. If you want a tilting arm, be sure it is rack and pinion. Look at other features that may fit your needs. As a Pegas dealer, I can help...
Today, 11:32 AM -
by Jim LowderI think the foot release was an option. I don’t see the pulley for it on the back of yours. Although it may have been removed. It is a very simple concept, it’s a cable attached to the back of the saw to release the arm
Today, 10:10 AM -
