Took the standard wobble bowl pattern (from Steve Goods site) and blew it up to roughly 12 inches in diameter to create this fruit bowl for my wife. Cut from scrap wood, finished in tung oil and 3 coats of clear poly.
Fruit Bowl
Tags: None
Thanks DW...
Jim, I have to agree with you about a 12 x 12 piece of wood being called 'scrap' LOL! This piece was an odd cut end piece off of a laminated board used for a table top - hence the term used. I don't think that I really look at any piece of wood as 'scrap'! Check out my wime basket from a 'chunk' of cabinet ply.
Today, 03:24 PM -
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
