calculating cut angle
  • calculating cut angle
    I glued up a blank to cut a bowl, but when I went to get my copy of Carol's book to calculate the cutting angle, I couldn't find it anywhere. I guess I never should have cleaned out the garage. Does someone have a handy chart out there for calculating cutting angle based on the thickness of the wood?
    Keith
    tan θ = opposite / adjacent
    θ = atan(cut width / wood thickness)
    Also check out Dave van Ess's Angle Calculator.
    IIRC, Carole recommends adding an extra degree to the calculated angle for the kerf.
    --Rob
      I should have paid attention in trig. I tried the angle calculator but it just doesn't seem right or maybe I am just not understanding. The blank I am using took a long time to glue up so I don't want to mess it up by cutting the wrong angle.
      Keith
        Keith,
        Sorry you misplaced the book, but I think I can help.
        It's really not all that complicated once you get the hang of it, but until then, it can be confusing. If you know the thickness of your wood (once it's been sanded, if you've done a glue-up) and the ring width (usually either 3/8" or 1/4") you can solve for the cutting angle. As Rob mentioned, I like to add an extra degree to account for kerf width and miscuts. If your angle is too large, you may have some extra sanding to do on the outside, but if the angle is too small, you may not have enough wood for gluing the rings together.
        The 3/8" wide ring gives more wiggle room than the 1/4" wide ring, but the thinner wall is a little more elegant, and you can use a smaller cutting angle which gives you more shaping options.
        Now, down to business. If you go to Dave's program (AngleCalc), enter the thickness of your wood as a decimal. Then, enter the ring width, also as a decimal. Go to where it says "angle" and click on "solve". The correct angle should appear. Round the number up, if necessary, and add one degree. That should work. However, to play it safe, send me a PM with your specs and I'll compute it for you. That way you can check your own work, and not risk ruining your wood.
        And maybe you'll find the missing book!
        Carole
          I'll bet you'll get the bowl all made, finished, and everything...
          And then when you go to get a rag to buff it,
          the book will be under the rag...lol.
          Rock and Scroll
          My Gallery
          My Website
          Featherwood Woodcrafts
            I used the book which I think said 20 degrees for 3/4" thick wood with 1/4" wide rings, but it was too thick on the bottom of each ring. The calculator says 18 degrees, and I calculate the same: inverse tan(0.25/0.75) = inverse tan(0.33) = 18.
              Block, if that works for you that's great, but it doesn't leave much margin for error.
              Can you clarify what you mean by the bottom of each ring being too thick? Thanks.
              Carole
                I think I was confused - a larger angle would of course be on both sides of each ring (all cuts in other words), so the top and bottom of each ring ought to be the same width no matter what the angle, right? My recollection is mine were wider on the bottom than the top, so maybe the blade was bending...but if it bent for both cuts, it would cancel out somewhat. Gotta head to work now...
                  Reply to Source for 5-Ply poplar plywood?
                  I do all my puzzles in 3/4” wood, mostly poplar but some cherry or walnut....
                  Yesterday, 10:57 PM
                • millwab
                  by millwab
                  Understandable for your baskets Betty, but in my experience 1/4” solid wood for puzzles tends to not hold up very well. Especially the small locks....
                  Yesterday, 08:57 AM
                  Planer do
                  Should read planer Died yesterday. But Bruce got out his instruction book and google and got it apart. Needs new belt, plastic cover and pulley gear. Ordered from eBay and should have by Monday. Of course all work on dough boards stopped. $55 is much cheaper than a new planer. Oh well, on to the next...
                  Yesterday, 08:48 AM
                  My customers won’t buy anything cut from plywood. I’ve spoiled them. I use poplar for all my kid puzzles. With Bruce volunteering at the County Park antique sawmill, I have an endless supply of poplar. My current batch is green and white striped. I make cases for all my puzzles and back them with...
                  Yesterday, 08:43 AM
                  Reply to Wood supply
                  I have enough of that. I bought 3 sheets of 1/8 and 1/4 a few months back. Bruce was at the sawmill yesterday and the superintendent of the Park told them they were getting over 50 oak trees from various county parks. The trees have sort of bug that is killing them . They will be quarantining them in...
                  Yesterday, 07:40 AM
