Here is what I've been wanting to do for a long time. I use walnut and the white part of ash. I was having problem with the ash burning and I changed from a # 5 blade to a # 5 precision blade and it solved my problem. I made a jig to cut my squares, which work good. I had a few people say they liked the burnt look, but I'll probably recut some of them. Comments welcome. Don
First coumpound cut chess set and board
Wow that's quite a job just to start and finish that project........you certainly did a sweeeeet job Frenchie. I like the way you beveled the squares.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Looks very nice to me - and I really like the beveled squares.
Larry; The chess pieces are from a Patrick Spielman book, I don't remember which one right off hand The Board was from the woodsmith mag Vol.22/ No.132 of course I didn't follow all of the instruction for it. It has a draw that pulls out from either side. divider for each piece and a place for checkers.I went as far as I dare. Don
Reply to Question about tilting head sawsby handibunnyIt doesn’t matter whether the saw table tilts or the saw arm tilts. Either can be used for any project cut at an angle, and there’s a learning curve for each.
I actually prefer the tilting table because the blade remains vertical. I find that at really steep angles, like 40 or 45 degrees,...-
Channel: Welcome Members
Today, 02:10 PM -
by will8989This is the tapestry I found in the cedar chest. We can’t identify where the pictures are from. Two among many. I also forgot to mention dad was also in the army Fife and Drum Corps and also played with a big band when he was discharged. Have to find that info....
Today, 12:34 PM -
Reply to Bruce doing greatby will8989What a morning. The therapists were quite pleased with what he could do. He took the wrap off today and he can walk with the walker with very little pain. It’s getting the leg completely straight that is hard to do. It’s when his brother stopped in that things went off rails. Rolf, we are talking...
Today, 12:19 PM -
Reply to Question about tilting head sawsby Sandy OaksIf you are referring to 3D Compound cutting, the blade is 90 degrees to the table and not tilted. I use the tilting head for things like inlays and Carole's bowls. If you want a tilting arm, be sure it is rack and pinion. Look at other features that may fit your needs. As a Pegas dealer, I can help...
Today, 11:32 AM -
by Jim LowderI think the foot release was an option. I don’t see the pulley for it on the back of yours. Although it may have been removed. It is a very simple concept, it’s a cable attached to the back of the saw to release the arm
Today, 10:10 AM -
