Thanks for taking time to post everyone, to answer a few questions: yes Carole the watch is a real pocket watch I took apart, yes the crystal is acrylic, and I used embedded magnets to pivot the cover.
Patty I lined the box with Suede Tex flocking. Lots of folks here use this stuff. You can purchase the adhesive same color as the flocking if you wish. Personally I just use the same color of latex craft paint mixed with some white glue, then use a salt shaker to "salt" the flocking on. Let it dry at least a day before shaking the excess off. Others have different methods, so if you want to try it, just search the forum for flocking.
I've used 1/4 and 1/8" blades from different sources with good results. I use carbon fiber blade blocks so I can put the blade in the middle of the blocks. You have to "tune" the blade for your specific saw. Several videos on YouTube on how to tune band saw blades.
If you google...
Very interesting and well done projects. I have not tried a 1/8" blade but think I will. Can you tell us the brand of blade, tooth count and what bandsaw you are using. Sorry to be asking so many questions but you have the knowledge. Also, any tips for using that small of a blade.
thanks Carole. I used the band saw with a 1/8" blade - not much different than the scroller but I have to use other methods to do the insides of the letters where the band saw can't reach. All the while, WISHING I had a scroll saw. and now, that I've got one, I'll be venturing back into dimensional...
Very impressive work, John. I like the tooled leather look, the detailed calligraphy, and especially the rendition of the brushes and other tools that you use for your craft. It will be interesting to see how you incorporate the scroll saw into your work, and the opportunities it provides you.
