As you may know I was having so much fun making boxes, they caught up to me...I found I had 9 of them setting on the bench ready for the finish to be added. That is allot of finishing to be done at one time...since I add about 6 coats to each box. I finally finished that job...here are most of them...a couple were already sold. I have cut out 5 more, but I am doing the sanding on two and them stop to add the finish. I still need to build a little paint area so they can dry during the day instead of just at night. Hope you like them. A few are my own design.
A few boxes
They are great little boxes.
All with the scroll saw?
It's all fun
Terry
Craftsman 18"
Delta 46-460 lathe
________________________
https://www.facebook.com/SillyLillyBowsAndMore
Thanks Carole, The last box and the big round box are what I designed. When making the center drawer on the round one, I cut the drawer guts out upside down... I glued it all back together, and re-cut it and you can't really tell...just has a thin cut line on the bottom of the drawer that I filled with glue and Koa sawdust.
Terry, these boxes were cut on the band saw. Most are 4" - 5" thick so can not be cut on the scroll saw because of size. They can be designed to cut on the scroll saw...just make everything much smaller and not as thick. I sell these to high end stores here on the Island, and the buyers seem to like the larger boxes.Hawaiilad
Larry
Very nice work Larry, nicely finished too. Great job.
Larry, it looks like you hit another home run on the batch of boxes!!! Are all these Koa, as it is amazing how different the wood changes! I swear, one of these days I am going to swim to the islands and bring a load home - lol!
I like how your own designs turned out...I knew ya had it in ya! What type of finish are you using, I know you probably said in an earlier post - but I have slept since then!
Terry, you can still make these with your scroll saw, using the ring method, and maintain the thickness. Just take your time with cutting and check the fit during each time you glue up another ring so that you do not have too much sanding to do or gaps where the drawers are. I usually cut the first 'ring' using a pattern, then trace the next ring in case I veered off the line, then cut the next ring tracing your previous ring (make sure to number each ring and mark the back side...I hope that makes sense.
Once again, great batch of boxes Larry and congrats on your $ale$!~ Kim
www.gonecoastalart.com
Thanks again Ladies and Gents. Kim I use Minwax Poly with a foam brush. I am not real good at spraying and I like the way the Poly flows onto the wood, but I am always looking for something better..Hawaiilad
Larry
Reply to What is it?by will898936mm. Bruce ordered the wrong size Forstner bit a few years ago and in his boredom this what he made with it.
Today, 09:06 PM -
Reply to Visitor questionby Bill WilsonDirty & cluttered have been co-mingling in my shop for so long, I can't tell the difference. 😁...
Today, 04:26 PM -
Reply to What is it?by Jim McDonaldFour partially drilled holes in a block of maybe oak?
Got to remember, I am pretty simplistic.-
Today, 01:57 PM -
