The jointer is jumping!! Making chain blanks
  • The jointer is jumping!! Making chain blanks
    I got up the nerve to try it!! I used a 1 1/2 1 1/2 poplar that I've had sitting around. Was really excited because I thought they were a different size, but they were perfect!
    I forgot to take the camera out with me to take pictures of the process, but I took some afterward to kind of show you.
    It was a bit of a balancing act, but really not too bad. I also had help! My husband kind of pulled back on the guard to start me through. It was a little difficult to push it through and hold it straight.
    Once I got started it would snug up nicely against the board and help keep it aligned.
    It looked really strange about half way through and I didn't think it was going to work, but by the time I got to 1/2 inch it was a cross!!
    I did gouge it a little on one side. But once I figured out the "touch" it came out pretty well.
    And voila.... 1/2 inch rectangle cuts!! It didn't take too awfully long, about a half hour. Took little bits at a time. I think it would be fast if I did it again.
    Just another "work around" for a problem!! Thanks for looking!!
    Cathy in NE
    Good for you. Just please always be aware of where your fingers are in that procedure it will only take a millisecond for a tragic outcome. I know a push stick will be more difficult to control but i would not feel real comfortable having my fingers that close to the jointer cutters. Looking forward to some more WIP pics of your chain. Whoooo hoo...
      "Ho lee chit" Cathy you are one brave woman, so glad it worked out for ya. Just be careful, make yourself some push sticks or something. Looks like a sweeeeet sturdy machine.
      Now comes the fun to scroll that cross. Good luck.
        Thanks for worrying about me Mike and Wood Dog! The jointer was not running when I took the photos. I used my push blocks for a long time, but when I got a really big edge on it I did just use my hands, but very carefully. I know this is a dangerous machine. I still like it better than a table saw!!
        Cathy in NE
          Good for you. You have been paying attention on here....GRIN! Looking forward to those pics.
            It looks great. A nice solution, and my jointer will do this, so thanks again for the tip.
              More power to you Cathy. The joiner and tablesaw are two tools in my shop I really respect. Not sure I would try what you did, but so glad it worked for you. So that was a chain blank you made?
              Hawaiilad
              Larry
                I have the Pegas replacement table for my EX21. It was the best investment that I made. The best part is they eliminated the useless vacuum holes and reduced the size of the blade hole as well. Another benefit was the table stiffened the EX21 frame eliminating much of resonant vibration. It is a much...
                Today, 09:45 PM
              • KarlB
                Reply to Shawl pins
                by KarlB
                That's what I was wondering Betty: If these would work (larger) for hair?
                Karl...
                Today, 04:47 PM
              • RJweb
                Reply to Shawl pins
                by RJweb
                Who said being bald isn’t a plus, RJ...
                Today, 01:18 PM
                The perfect solution when I need a wider top on my Hegner. A magnetic sheet! I decided not to get the Pegas as the only reason was for the wider top and the top feed blade. After 19 years, my Hegner is still running like new and I couldn’t justify the expense. It was a “want” and not a “need”....
                Today, 12:27 PM
                Reply to Shawl pins
                Good idea Scott. Also, my daughter has long, curly hair. She twists it up and around and sticks a pencil in to hold it. I also stick a dowel in my hair when working and my hair gets in my way and I twist it up. The one in this picture would perfect for thick hair.
                Today, 12:19 PM
