When I have read instructions on cutting bowls, they say to cut in a particular direction (i.e. counter clockwise). Other than the direction, how does this affect the final product.
Cutting Direction
The easiest way to explain that is to actually try it. However if you put the table in a left side down and you cut your ring so that the blade is cutting the line clockwise you will get a ring that will have a larger diameter on top than it does on the bottom. If you cut the other way it is reversed. Does that make any sense? Try it and you will see what I am trying to explain.
John Wayne
When a table is tilted, the direction of the cut determines which side of the wood, top or bottom, will be larger when the piece is cut.
For bowls, for example, the most common way to cut the rings is with the table tilted left side down, cutting clockwise. This means that the wood is fed in a counterclockwise direction, which makes the blade look like it is moving clockwise.
If the saw table will only tilt right side down, substituting clockwise for counterclockwise and vice versa will give the same results.
As DW said, you have to try it to see how it works. It's less complicated than it sounds.
Reply to The St-Nicolas sheriffby planeurThanks gang !
And Wayne thanks for you advise which is quite good. After a good look at my men, as you said, with the hat I will work on the ears and his big mustache . I will try to rounded those parts as I did with my heron.
But in person he is more 3D than on the photo....-
Today, 10:09 PM -
Reply to FInished Productby KarlBGreat looking! Very impressive work.
Today, 08:51 PM -
Reply to FInished Productby will8989That is beautiful. What are you going to do with it?
Today, 08:12 PM -
by tgiro01Some folks expressed a desire to see this thing once it was completed. This is the bowl I experimented on, with the little Kobalt miter saw.
The downside is that, I used Hickory for most of the bowl. Hickory is a hard brittle wood but, it also has an open grain, which promptly absorbed...-
Today, 06:52 PM -
