movin the compound cut pattern?
Yea, I've fudge it a tad myself without a disaster, but do it before you start cutting the project. I've cut patterns from Keaner book, I forgot his first name, but he drew patterns without a dotted center line, so you have to just center it the best way you can. another option is to print out the pattern at 90, or 95%, so it will fit your wood better. Compounds are so cool to cut, and you did a sweeeet job on your project.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
WD,
Had the perfect answer for your question. You did a nice job on the ornament."Still Montana Mike"
Excellent job on the ornament. Either using a slightly larger piece of wood or slightly shrinking the size of the pattern when printing it out works as well.
John Wayne
Cutting through the pattern issue on other side. This has happened to me when I did not start my initial cut from the top or bottom. If you have/want to start your cut on a "side wall" you must be careful that your "opposite side" pattern is facing you.
Tim,
are you using clamps or did you make a clamping device like i use with 2 carriage bolts and a wing nut.."Still Montana Mike"
Sounds like your table to blade is O.K.
My guess for your next question is that you are using pine.......?
nothing wrong with that but it acts like what you describe.
Try using clamps or the jig Mike spoke of, one thing you don't want is the middle piece flopping around while cutting. Personally I like the small Quick clamps, but it's just a personal preference. Good luck.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
by jim_mexHi Betty - you surely have one heck of a lot of patience in dealing with Bruce!!!
The important thing is that he appears to be heading in the right direction and hopefully it won't be too much longer before you can both put these issues behind you. And once he's recovered with your invaluable...-
Today, 01:31 PM -
Reply to FInished Productby jim_mexBeautiful inspiring work Tony!
Glad to hear that the Kobalt saw worked out very well.
FYI - I took delivery last week of a SKILSAW 8 1/4" blade portable table saw to assist in cutting pieces for segmented bowl work which I was very pleased to find out of the box was set...-
Today, 10:58 AM -
Reply to The Vikingby RolfThis is the definition of spalting, Basically it changes the color of parts of the wood as it decays. Turners love it.
"Spalting is any form of wood coloration caused by fungi. Although primarily found in dead trees, spalting can also occur in living trees under stress. Although spalting...-
Today, 09:10 AM -
