Follow-up: Plywood Collapsible Baskets
  • Follow-up: Plywood Collapsible Baskets
    The responses to my question earlier this month encouraged me to cut one of the Longabaughs' patterns. I knew it would be a learning experience and wasn't concerned if the end result was not a keeper. I installed a new FD Polar blade (#9 as recommended by the Longabaughs) and used a decent looking scrap of 3/4" cabinet grade plywood. Using the highest speed on my Dewalt scrollsaw I easily sawed the outer and inner outlines. Everything was going great. About a third of the way through the spiral part of the pattern I realized the cutting rate had slowed and remembered reading what plywood glues do to the sharpness of scrollsaw blades. I should have stopped then and replaced the bade. I didn't but continued to cut the rest of the spiral. That was a mistake. The cutting accuracy for the rest of the spiral was definitely diminished, As it turned out the basket looked OK except there is disfiguring part of a ply that almost looks like cork. In assembly the screw I used split the foot: too small a pilot hole?
    I have some solid wood I will use for my next effort. One question: if replacing a blade in the middle of cutting the spirals would I have to go back to the starting point and bring it to the cutting point with the saw turned on?
    Poor quality picture attached.
    Harpone, Nice try on the duck basket. When you drill the part of the duck I would use a dril the size of the screw. When drilling the basket I would use a small pilot hole. As far as starting at the starting point with a new blade no you can start where you left off. Lance
      Thanks for the advice.
        Nice try Hapone. It had to be tried...now we all know
        Hawaiilad
        Larry
