Something I made for the front door. Not quite sure that I like the paint effect. May re-do it
Guardian Lion
The painting seems to grow on you after a while. Nicely done."Still Montana Mike"
That is neat! If you plan on repainting, before you repaint the whole thing just try putting some of the dark color into some areas on the light for highlight. Like around the nose area and in the mane and tail. It would tie it all together a little more. I like the 'velvet' look you have gotten with the paint.
Hi Kiwi, great looking lion! I understand what you mean about the paint technique...were you going for a distressed look or trying to mimic the texture of hair?
This is just a suggestion, so you can shrug it off if you like. If you are looking for a distressed look it can be done fairly easily, as I use it all the time for my outdoor beach signs I sell. I paint them in layers, using similar colors with the dominant color on top. Believe it or not the sloppier (brush strokes and such) the better. Once all the layers of paint are dry then take a sander or sandpaper with 120 grit and lightly sand it so the other colors come thru and even some of the bare wood. Then once I like how it came out, I dust it off and use a light color stain, leave on for a few minutes and then wipe off excess until you get the color you like. Once all dry I add atleast three coats of an outdoor clear coat (I just use an inexspensive spray on by Krylon). I hope that makes all sense. Like I said, just a suggestion.~ Kim
www.gonecoastalart.com
Reply to The Vikingby planeurIncredible piece ! WOW , so much fines works. I see that I have still a lot to do before being as good as you!
Question : how many species of wood in the viking?
And what is the meaning of : though some is spalted.
planeur-
Yesterday, 10:30 PM -
Reply to The St-Nicolas sheriffby planeurThanks gang !
And Wayne thanks for you advise which is quite good. After a good look at my men, as you said, with the hat I will work on the ears and his big mustache . I will try to rounded those parts as I did with my heron.
But in person he is more 3D than on the photo....-
Yesterday, 10:09 PM -
Reply to FInished Productby KarlBGreat looking! Very impressive work.
Yesterday, 08:51 PM -
Reply to FInished Productby will8989That is beautiful. What are you going to do with it?
Yesterday, 08:12 PM -
