Sweeeeet clean sharp cuts DW. Did you notch out for the star 2 points in the side wall, or are my eyes playing tricks on me again? Looks great overall.
Carole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
That is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
Just a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
