there fun to cut, I still have to make the dirds the wood is wallnut. I used pine for the deer he's 3/4 x2 x21/2 ". Lance
My first compund cut bird houses and a deer
Two more picture's of deer.Attached Files
Very nicely done. Welcome to the addictive world of miniature birdhouse cutting. Looking forward to seeing more of your work and like Anneh would like to know where you got the deer pattern. Thanks for sharing them with us.
John Wayne
Anneh and Dwsudekum
I got the reindeer here. 3-D scrollsaw reindeer pattern
I shorten the neck so it wloud be less likely to break. I used two 3/4 " plne glued togrther.
Lance
Thanks a bunch for the reindeer link Fireglass, something tells me we will have enough to fill all the birdhouses around here............Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Originally posted by fireglassanyone made any deer yet?
IMG_5935 (Small).JPGGloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Reply to Rikon Air Cleanerby cwmageeI wish Bruce a speedy recovery. If his recovery is similar as that of a friend he will be up and around in no time at all. My friends is over weight and had both knees done 5 days apart. Physical therapy helpd alot.
Today, 08:47 PM -
Reply to rbi Hawk scroll saw springby TangoI had to replace the motor on my Hawk that we purchased new in 2002. I just called up Hawk & they had me send them my motor the power switch. He needed to collaborate the new motor and to my power switch. The new motor was sent back with in the week. I did this back in 2018 and it was a little...
Today, 04:06 PM -
Reply to Help with spray adhesiveI've tried label paper as well. It peels off reasonably well, although different brands will probably perform differently. When it doesn't come off easily, I have a little heat gun that makes release quickly. When I have used 3M spray adhesive and left it on for too long, a hair dryer or heat gun...
Channel: Beginners Scroll Saw
Today, 02:47 PM -
Reply to rbi Hawk scroll saw springRolf, What is the voltage, H.P., and rpm on the motor on your G4?
Today, 01:06 PM -
by planeurIt is me again....😉 with an other try which I think is the good one.
Lets compare :
the original stained glass before it broke
the same with broken glass
my first work to fill the hole
or
Today, 11:34 AM -
