Hello! I am excited to have completed my first little bowl! I would like to thank everyone for all of the good advice I have been reading on this forum. It opened my eyes to so many tips and ideas. Angles were my enemy on the first 2 attempts at bowl making on a scroll saw. This little cherry bowl stands only 2" tall but has me wanting to try more! Its finished with mineral oil only at this point. Thanks for looking! Tammy
Small Cherry Bowl
Very Nicely done Tammy. Cherry can be a difficult wood to work because it can burn easily. Thanks for sharing it with us. Now that you are hooked looking forward to seeing more of your work.
John Wayne
Tammy, Dave, and anyone else new to bowl-making, to make it even easier, go to Dave Van Ess' site, scrollmania.com, and use his angle calculator.
In addition to rounding up to the larger angle, if you are using a 1/4" thick ring, which gives less leeway for cutting errors, you can add on an extra degree to your cutting angle. Excess wood on the outside of your bowl can easily be sanded away, but if your ring comes out too narrow, you may not have enough wood for gluing up.
You might find it helpful to check out the bowl-making videos that can be accessed on this site from the side bar, and from my blog.
Looking forward to seeing more nice bowls!
Great job, and thanks for your post - the lightbulb went off in my head when I saw that you started out with a really small bowl. I've been wanting to try to make a bowl, but was envisioning something a great deal larger and just wasn't up to trying something that big and potentially ruining that much wood. I am DEFINITELY going to try a small one, and thanks to all with the tips about the angles and sanding etc.
Patte, with only one exception, every bowl in my book was cut from a piece of wood no larger than 8" x 8". That's one of the beauties of this approach--even if the project is a complete disaster, the wood loss is minimal. Some folks have taken to making larger bowls, but that's not typical, given the relatively small size of the saw table.
For starters, try a 2-ring bowl. That's deep enough to look like a bowl, not a tray, and small enough to be quite manageable. Looking forward to seeing your work!
Thanks for the info Carole. I did infact use the angle clac on the scroll mania site. And to get my old delta and little drill press lined up to the right angle I downloaded a digital level app on my droid phone. Works like a charm!!
Go for it Patte! Its fun!
TammyTammy
Originally posted by sqrlalrt View PostHello! I am excited to have completed my first little bowl! I would like to thank everyone for all of the good advice I have been reading on this forum. It opened my eyes to so many tips and ideas. Angles were my enemy on the first 2 attempts at bowl making on a scroll saw. This little cherry bowl stands only 2" tall but has me wanting to try more! Its finished with mineral oil only at this point. Thanks for looking! Tammy
It's only 2 inches tall? I personally think the smaller the bowl, the more challenging they are. Great job!
SQLast edited by susieq4131; 10-01-2011, 10:46 PM.If you can't fix it with sawdust and glue, it's not worth fixing.
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
by cwmageeCarole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
Today, 08:40 AM -
by RolfThat is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
Today, 07:28 AM -
