Two scrolled bowls finished on the lathe
  • Two scrolled bowls finished on the lathe
    Here are two new 10 inch diameter bowls made from maple. Cut out the rings, glued them together, and finished them on the lathe. Second bowl, I made up two bowls the exact size, and swapped the rings around.
    Finish is USP grade mineral oil and beeswax.
    SQ
    If you can't fix it with sawdust and glue, it's not worth fixing.
    Beautiful work, as always, SQ!
    Carole
      Very very nicely done SQ! I like them a lot. Thanks for sharing them with us.
      DW
      John Wayne
        Very nicely done! God Bless! Spirithorse
          Beautiful job.
          Linda
            Very nice SQ....I have been reading of others that are doing the sanding on the lathe. Not having a lathe around, I will have to stick to the original way.
            Hawaiilad
            Larry
              Beautiful workmanship.
              DeWalt 788
                Carole, thanks for the very kind words. I love making these scrolled bowls, and it's all your fault.
                SQ
                  Thanks everyone for all the nice comments.
                  Larry, I first smooth the bowl out with the different turning tools and then once it's as smooth as I can get it, I sand it while still on the lathe. Nothing wrong with sanding the original way. It works equally well.
                  SQ
                    Do you find it takes less time to round out the bowls using the lathe? Once again another reason I should have held onto the lathe I had..
                    Hawaiilad
                    Larry
                      It has saved me lots of time. I am still scrolling the bowls like I learned from Carole's book and gluing up the rings. I start on the outside of the bowl and clean up the layers then move into the interior of the bowl and do the same thing with the different turning tools. The basic shape is there, I'm just taking off all the rough edges. Then I sand it with a Grex 2 inch air sander. The resulting symmetry is what I was after and I'm very pleased with the results.
                      But don't jump into a lathe without instruction. How you hold the turning tools and where you place them on a turning vessel are rules one must follow to turn anything safely.
                      SQ
                        Very nice bowls Sussie.When you ,first, tell me about finishing on the lathe I was thinking at some considerable change on outside shape of the bowls .I think so this is possible if the rings are thicker in diameter.Why not ? some flower vases could be done this way ,with some PVC pipe ,or jarr,or cutted bottle inlay for water proofing.
                          Nice! I love the wood grain!
                          Tammy
                            Originally posted by susieq4131 View Post
                            Here are two new 10 inch diameter bowls SQ
                            The bowels look extremely well done. I like them !
                            For a 10" bowl are you using 10" wide boards for the largest ring ? Or are you edge gluing narrow boards to get the 10" width ?
                              Epson,
                              Thank you! It is so good to hear form you! Hope the family is doing well. Outside edge could be shaped in many different ways and I agree thicker rings would help make that possible.
                              SQ
