Dewalt 788 blade movement - side to side
  • Dewalt 788 blade movement - side to side
    I have an older Dewalt 788 (type 1) that I have had for at least 15 years. I have been doing Christmas ornaments and pictures but recently starting doing coins. I have noticed that there seems to be a lot of side to side movement on the saw when I am trying to cut really fine details. Is this an adjustment setting and if so how to I correct it?
    https://www.youtube.com/watch?v=QK4LytR2kYA
    --Admin note: Click on this ^^ link. Ignore the link below. I can't remove it for some reason.
    First video with numbers and letters is correct.
    this post is totally messed up, I can't change to the correct video, it won't let me remove the video link or delete the post! It is going into a Youtube beta editing area
    It also won't let me remove the link to the video or change to another one!
      How do you delete a post?
        I believe an admin. Or someone authorized to asssit the admin. is the only people authorized to delete a post. I do not know why you cannot edit and delete the link.
        Melanie from East TN
          They are probably not going to guess my password to youtube as it is 14 characters punctuation and numbers long
            Jeff, please PM me the correct link. I can't delete the link without providing a new link.
            www.GrobetUSA.com
              Some of the side to side movement could be caused by the blade not being centered in the holders. I use a piece of plastic to at least get the top and bottom set screws to the same distance. if you run the saw at the slowest speed and set something next to the blade you can tell if that is the problem. Hoping someone can explain this better than I can.
              The other John A. Nelson
              johnsworkshop.com
              sigpic
                My idea was the same as Johns', the set screws in the clamp will dictate where the blade sits in the clamp side to side. I would try adjusting the set screws to eliminate the side to side by bring top and bottom inline with each other. On my coins, I can handle the front to back motion easy enough, but side to side would be bad.
