I have a five year old DW 788. My issue is that the blades are coming loose too often, sometimes at the top, sometimes at the bottom. The threads on the thumbscrews look good (not crushed). Should I rough up the contact points? I usually tighten the blade so it's at a "3" or "3 1/2" on the dial. Appreciate any ideas. Thanks. -John S.
Blade coming loose too often
Yes, rough the ends of the blade clamp screw a bit. Shouldn't take much, just a scuff with some sandpaper. They must remain flat so that you get contact across the full face of the Also, do you clean the ends of your blades before inserting them into the clamps? If not, that will also help a lot. Make sure the tip of the clamp screw will rotate. It's an insert that fits into the end of the thumb screw and it should rotate so that when you tighten the clamp screw, it doesn't twist the blade out of the clamp.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
The blades sometimes have a thin layer of oil. This may cause the blade to slip out of the clamp. Sanding the end of the blade should help with this, but you may also have to clean off the blade clamp and thumb screw.
- Likes 1
Something Ray taught me --
Take a 2 X 3 inch long piece of 3/4 inch thick pine. Use a 7/32nd drill and drill two holes about an inch apart. Screw the set screw into on hole and the thumbscrew into the other hole until the clamping surfaces are just flush with one face of the wood. Place a 220 grit piece of sandpaper flat on a table or bench - lay the face of the wood with the clamping surfaces on the sandpaper and run the piece of wood back and forth on the paper. As the paper sands the wood, it, also, cleans the clamping surfaces. Once the clamping surfaces have any nicks or shiny spots sanded off, remove the screws and replace them back in the clamp. A touch of blue Loktite holds them securely.Tony
- Likes 1
I find that the fingernail sanding sticks like my wife uses work great to clean the ends of the blades off. Each one lasts a long time and they are not expensive. I sand all four sides of the ends until the blade is shiny.
They can also be used in light sanding in thin long openings.
Reply to Clock hardware Kits.by RolfI sent you a private message with my E-mail...
Channel: Author Questions
Today, 07:50 AM -
by John SmithTo answer your question about the saw that I have:
my first one was the 12" Craftsman from the late '70s. (put a LOT of miles on that one).
Sold that one in 2000 when I closed the shop.
then, in 2004, I got a 10" Delta Table Top just for hobby work. (I used...Yesterday, 05:24 PM -
Reply to Clock hardware Kits.by Ralph123How do I go about ordering one?
Yesterday, 03:52 PM -
by John SmithI've used 1/4 and 1/8" blades from different sources with good results. I use carbon fiber blade blocks so I can put the blade in the middle of the blocks. You have to "tune" the blade for your specific saw. Several videos on YouTube on how to tune band saw blades.
If you google...07-02-2022, 09:57 PM -
...07-02-2022, 07:31 PM
