Old Hegner Multimax 2 Blade Clamp Problem
  • Old Hegner Multimax 2 Blade Clamp Problem
    Total beginner here. I bought this 1983 Multimax 2 in an estate sale with nothing but an envelope of blades and the original bill of sale. It looks in good condition.
    1. Googling, I can't find a manual for the Multimax 2. It looks similar to other models but I still can't determine how to adjust things.
    2. I mount the blade into the lower blade clamp OK. But even backing off so it just barely clamps, there still isn't enough length to insert in the top clamp. I've released all the tension on the upper arm to lower it, but the blade still cannot reach the clamp enough to clamp securely. The blades came with the saw and are all the same length so I assume they are the correct length? I'm sure I'm missing something but I'm not sure what.
    3. If I could get the blade in both clamps, it would be up against the left side of the hole in the table. There doesn't appear to be much leeway for moving the blade side to side out of the way. Am I missing something else? Is there a way to adjust the blade or the table to clear the hole?
    Any help would be appreciated.
    i use a hegner multicut,and assume it is much the same,ajust the tensioner at the back of the saw so your blade is slack when you pull the tension lever,if there is one .do you have a picture of it.
    lets make plenty of sawdut,
    and have fun doing it
    http://www.customcutz4you.webs.com
      Hi,
      I have a newer Hegner but here is the US dealer werbsite with information and parts.
      https://www.advmachinery.com/
      Call them for help.
      Thanks
      Bill
      DEWALT 788 and Hegner 18vs..... AND STILL CUTTIN IT UP!!!!
      Member of Scrollsaw Association of the World
        I have two Hegner saws. A Polymax-3 (2008) and a Multimax-3 (1986). As has been said, advance machinery will help you with any issues you may have with your saw. Good folks there. Parts for my saws are still available from them so I bet parts for your saw are too.
        Hegner Polymax- 3,Hegner Multimax-3,15" Jet
        You may have your PHD but I have my GED and my DD 214""
          Thanks for the advise. I will call Advanced Machinery. The tension is totally loose. If I discover the problem, I'll report.
            Reply to clock inserts
            I also get mine from Sloans. http://www.sloanwoodshop.com/
            Just know that you have to phone in your order, their delivery is fast and very friendly folks.!
            The problem with any of the inserts you never know when they were made and how old the battery is. I bought a bunch of inserts...
            Today, 07:54 AM
          • jttheclockman
            jttheclockman
            What size and where are you buying from.
            Yesterday, 11:36 PM
            Reply to Puzzle boxes
            will8989
            Actually, it was about the animals stacked on top of one another. For some reason I can't find that issue. And my secret was about turning my alligator into a horse. Thanks for the info on Iggy and Scott. I will definitely check it out.
            Yesterday, 11:28 PM
          • dgman
            dgman
            I've had good luck with the inserts from Sloan's Woodshop.
            Yesterday, 09:23 PM
          • WHODAT
            clock inserts
            WHODAT
            i use alot of clock inserts but always have problems with them usually not working after awhile i've tried about 4 different companies always the same problems anybody have a hidden places i don't know about.
            Yesterday, 08:01 PM
