Can someone who uses Rapid REsizer give me some guidelines on using it...I have a jpg file saved and want to size it to fit into a 11x14 frame and print the color in red, just easier to see the lines...but can't seem to get it to work...doesn't seem to keep the proportions correctly....tks in advance...Dennis
Rapid REsizer guidance
Hello Dennis,
First, open your pattern in Rapid Resizer.
Next, select "Edit" from the top menu area, then select Tint Red, answer the question "Yes" and all lines should be red.
Then type in your height of 11, making sure your proportional box is checked, and the width will be calucuted automatically based on the size of the pattern that you imported. you can size the "box" around the pattern by dragging the dashed lines.
Hope this helps, it is much easier to do than to explain..."Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. Platt
BWF hit the nail right on the head. It is a very simple program to use, (or else I wouldn't be using it) Maybe is you told use what problem you are having it would help more.Chuck D
Jean De La Bruyere...
l
Originally posted by Dennis TaylorMy problem is in the resize, I try to put in the height & width of the pattern, 11x14, but it sounds like I only need to enter one size and it will resize from there to keep it in proportion, is that right?....Dennis"Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. Platt
So let me make sure I got this right. I can get the program, scan a Zaffino pattern onto PC and use the program to enlarge it to a 16x20 pattern that will print out in multiple sheets that is marked so all I have to do is tape them up and go to it? I have numerous Zaffino patterns that are I can only enlarge to 11x17 at most with copier and can only frame at 14x18. There are several that I want to do and frame as a 16x20 because I think they would look better and be more eye catching.
Do I have this right?Confuscious says, "The cautious seldom err".
That's correct Capt. I've used Rapid Resizer to print patterns at 16 X 20 (and larger).
MS Publisher will do the same thing in poster mode (print any size you want on multiple sheets).Kevin
Scrollsaw Patterns Online
Kevin, you are my hero ( again ) !
I have Publisher and never realized it could do this . I just tried it and it worked perfectly ! Thanx very much for the tip...~Robert~
DW788 and Hawk 226
Just tried again with the program and I remember why I ditched it. It printed the wrong way.
I see my pattern full size and I enter the size and it prints it sideways so I only get 1/4 of a page.
Something is wrong if everybody else likes it. I will flush it again and look for something else.
DianeDragon
Owner of a nice 21" Excalibur
Owner of a Dewalt 788
PuffityDragon on AFSP
Don't know what to tell you Dragon, it works like a dream for me."Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. Platt
Dragon, this may be a foolish question - did you check your printing preferences for page orientation and pages to print? Reason I mention this is printers have preference settings and sometimes I forget to reset mine after doing a special print job such as only 1 page of 3. The next time I print something else only one page prints. Then with a slap upside my head I remembered - need to change the setting.
Paul
Paul S.
by leehljpI haven't posted in a few months but I have been keeping up. I agree with what Mark is saying. To make everything for everyone would be very difficult. And I understand (from my wife's perspective) that computer apps are totally made for nerds - in her opinion. The breakdown is often between two of...
Yesterday, 11:37 PM -
Reply to Old Tool - Rebornby will8989I really like that. Will have to show it to Bruce.
Yesterday, 10:47 PM -
Reply to YoraHome Laser w/CNC Engraver/Routerby evilbadgerYes I'm still using the one I built I did some upgrades to it though. I swapped out the pipes for linear motion rails and made the gantry out of aluminum. I guess if I were to upgrade now I would be looking for a full size machine that could do 4x8 sheets of plywood with an automatic tool changer but...
Yesterday, 09:28 PM -
Yesterday, 03:24 PM -
