Brand new to the Scroll Saw and have a question regarding speed settings. I have a DeWalt DW788 and am wondering what the basic rule of thumb for setting the proper speed? Thanks in advance
Proper speed setting
With a higher speed the blade will cut better. If the speed is too low you tend to push a little too hard into the blade and the blade will start cutting with a bevel. Tension is very imported. Not enough, you lose control and will break a lot of blades.
MikeSD Mike
too much speed can break blades too. with jewelery blades I find the tension and the speed need to be at a bare minimum. With a big blade you can really let it roar, but I prefer a little less than half speed. With a big #9 blade at a slower speed you get to the end just as fast but without any burns. A slower speed removes more material per down stroke.Jeff Powell
As fast as you can while maintaining control without burning the wood.
I rarely go below the top three settings on my 788.
When you're cutting for craft shows or selling to friends, etc., time is money whether it's cutting pieces out or sanding burn marks or burrs.Last edited by Woodbutcher68; 02-27-2007, 06:50 PM.Fred
Looks like lots of opinions and good advice.
I tend to cut slowlyI like more control and I am never really into production. I agree that faster speeds can give to a smoother finish and I like faster speeds when cutting straight lines, but most of the time I cut at 500 SPM. Like I have said before I savour the cutting like a nice steak dinner.
Hmmm my mouth never watered from scrolling before!CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
The speed you choose depends on a lot of things. The thickness of the wood, the blade you're using, the type of wood you're cutting, if you're doing inside or outside cuts, all these make a difference.
Personally, I use a slower speed when I'm in thin wood or doing intricate (tight radius) work, a medium speed when doing medium thickness inside work, and a higher speed when doing outside work. I use a slower speed with smaller blades and a faster speed with larger ones.
This works for me. Your mileage may vary. Just keep on keeping on and you'll develop your own technique. Scroll on, dude.
Reply to What do you think?by Gary beasleyI tried a house vac once for a dust collector. It was prone to clogging the lines and when I tried to put a cyclone can on it the vacuum collapsed the garbage can.
Yesterday, 09:29 PM -
Reply to Vasesby Gary beasleyI found this pattern in Steves catalog and freehanded a vase form. This one may appeal to the folks that bought the butterfly vase.
...Yesterday, 09:25 PM -
Reply to My lucky day!by Bill WilsonBeing younger than 65, with no qualifying health conditions, I don't anticipate getting a vaccine for some time. My wife works for the school district, so she may be eligible in the next phase. President Biden says that supply will be sufficient for all US adults by end of May. I'm hoping that proves...
Yesterday, 04:16 PM -
Reply to What do you think?by MidMich324Will a shop vac work for the table saw?.
Yesterday, 11:26 AM -
