tension questions
Like Mike, I keep my bandsaw under tension permanently. Perhaps this is bad practice but I've never really thought about it.
The scroll saws are another matter. My Hegner came with a big warning in the instructions (we all read instructions carefully, don't we? ) that the saw should not be kept under tension when not in use. So I work on the principle that what's sauce for the goose is sauce for the gander and loosen the tension on my other saws when they're not in use too.
Mike and Gill:
The bandsaw tension:
Per the Bandsaw handbook by Mark Duginske, published by Sterling press, the problem is the bandsaw wheel tires will develop a flat spot, and over time the tension spring will lose its stiffness.
A Flat spot on the bandsaw wheels is a place where saw dust can accumulate. That may result in "flutter" .
The spring losing its stiffness makes the blade tension scale very inaccurate. You could run out of tension and spring range when installing a re-saw blade.
Replacing the tension spring is no big deal. In fact now there are third party after market replacement springs that are sold as "New and Improved."
However, replacing a band saw wheel rubber tire is a real big deal. This is a full Saturday event the first time you try it. Not hard, just time consuming. All kinds of jigs to make. A real PITA.
Phil
Thanks Phil - time to 'detune' my bandsaw, methinks.
I'll pass this info onto my hubby. He maintains the bandsaw and I remember a conversation (vaguely) about tension on the bandsaw when not in use but don't remember what he did about it, if anything. Infact more I think about it I doubt he did anything because I just put my wood on it and start cutting without doing anything. As for the wheels, he did replace them not too long ago with the new ones on the market and it did take him about 3 hours!
BettyBetty
I always tension both my scroll and band saws as high as I can before using them. A stiff blade is essential to a good, straight through cut.
When I'm done, I release the tension. On the scrollsaw, I also release the top of the blade holder.
Reply to Wood identification neededby RolfThis site should be on every woodworkers computer. https://www.wood-database.com/ As has been said the first image is Wenge....
Today, 07:38 AM -
Reply to I decided I needed a challengeby handibunnyI couldn't resist (too long since any new toys) and ordered a blacklight flashlight from Amazon--same price as Harbor Freight. Should be here Tuesday--can't wait to see all the glue spots I've missed.
Channel: Works in Process
Today, 07:01 AM -
Reply to Wood identification neededby handibunnyIf you google "Moradillo" you'll get more information than you'll ever need. It looks like it will work up beautifully.
Today, 06:59 AM -
Reply to Wood identification neededby dgmanThe first picture is Wenge, pronounced WHEN-ghay or WHEN-Gii. It is a very hard wood. It’s splintery and very hard to cut. When finished, it is almost black. I use it when I need a black wood for Intarsia. I do not know anything about the other wood.
Yesterday, 10:40 PM -
by vgrafI have a new neighbor who did a lot of woodworking in the past but had to give it up because of allergies. He sold his shop equipment and wood stockpile when he moved here, however he kept a few pieces of fancy wood and showed them to me. The first one (First Photo) he had no idea what it was. It is...
Yesterday, 09:31 PM -
