I did about 3 fairly simple projects on my Ryboi, then recently bought the Dewalt. I will say, that it isn't even the same hobby working with the Dewalt and the Ryobi. I am in the midst of the my first Dewalt project. For full disclosure I should mention the following. I went out and bought an EZ LIft over the weekend and think it is installed correctly (it works well anyway). I am using a craftsman spiral blade (.032 kerf I think), and the project is stack cutting 3 sheets of 1/4 inch oak ply. Oh and yes, I am placing my order wfor FD blades immediately. Now on to my questions.
I spent the time to center the blade clamp when I first brought the saw home. As I have gone through my project the *screw* in the top left of the blade clamp seems to slowly retract left. Is that even an understandable statement? Maybe it turns a little each time I tighten the blade clamp on the right. Is this a known *thing*/problem/issue*? I am assuming using some threadlock would be the wrong thing to do.
This one might seem silly, but oh well. Do most of you 1) open the blade clamp and then loosen the tension or 2) loosen the tension and then open the blade clamp. Seems like if I do 2 it bends the blades a little.
What tension do most of you need to move your Dewalt to. I almost always have to go to at least 5 to get the high C (or at least what I think is the high C)? Is it blade dependant? The EZ Lift doesn't seem like it shoudl have any effect, but the sound I am getting now is not quie as high as I was getting before. Maybe I knocked something loose.
Any tips on the blower. It seems like I can never get the blower in a good spot and then when I do, I need to move it to thread through the next whole. Tips?
Thanks for all your help in advance. Reading previous posts has helped a lot in the purchase of my saw, ordered blades, and lots of other tips.
Jordan
Jordan
