blade choice for cutting wood gears
  • blade choice for cutting wood gears
    Hello,
    I'm pretty uneducated regarding the scroll saw, so I was hoping to get some advice on good blade choices for the clock project in the current issue of the magazine.
    I have a 16" Craftsman VS scroll saw (that accepts the flat style blades, not the pin type) with a spiral blade. On the tooth cutting, would the spiral blade be a good choice, or is a regular blade better?
    Any tips or tricks would be much appreciated
    The article suggests a #1 reverse tooth. Why don't you try that?
    Mike
    Scrollin' since Jun/2006
    My Gallery
      I wouldn't use spirals at all. Marc said the cuts need to be VERY accurate for the clock to run properly. I'd use the #1 that he suggests!
      Bob Duncan
      Technical Editor
        I'm really new at this too and have done some practice or test cuts with spiral blades. What a waste of money! The blade seems to shread the heck out of the top and bottom of the wood and requires a lot of sanding to finish it properly. Not only that, but gaining control over the sprial for intricate cutting is a very difficult task. I've basically thrown the spirals to the back of my drawer and have resolved myself to practicing with the regular blades.
        Mia
        We are the music makers.
        Easy scrollin' with a DW788
          I use both blades pretty interchangably now, but it took some practice. I found it easier to learn with straight blades, then learn how sprials cut differently and go from there.
          You can't go wrong learning to use both!
            Hi All
            This may seem like a silly question.But what do the numbres mean when deciding on which blade to use.Right now I am flying by the seat of my pantsand picking one that does the right job without a lot of extra work.
            Thanks
            JWH.
              JWH -
              The bigger the number, the thicker the blade and the fewer teeth per inch - which will be a more aggressive, coarser cut. Mike's Workshop has excellent information about blades http://www.mikesworkshop.com/blades.htm and choosing them http://www.mikesworkshop.com/whatblad.htm and Mike is a pleasure to deal with.
              Slightly confusingly, when the blade numbers get down to 0 they then go 2/0, 3/0 etc... for even finer blades.
              The trade-off is between intricate cutting of thin wood with lots of control (low numbers, lots of teeth per inch) and fast cutting of thick, hard wood (high numbers, fewer teeth per inch).
              It's a bit like picking golf clubs. It's nice to have a wide range of choice, but most scrollers get by with a few personal favorites that they use all the time.
              Saws: AWSF18, Meccano Mk II
                Thanks for the info I have printed a copy off and I willbe ordering blades in the next couple of days.
                Thanks again.
                JWH
                  Hi JWH;
                  Check you PM's
                    blade choice
                    In a recent email from Marc Tovar, here is his blade choice
                    for cutting wooden gears =
                    I use all the blades of the Flying Dutchman-2-way cut.
                    Thats two teeth down and one up.
                    I use the No. 3 for 1/8" material,
                    the No. 5 for 1/4" to 1/2".
                    The No 7 for 1/2" and
                    the No. 9 for thicker material.
                    The 5 and 7 are the two I mostly use and buy them by the gross.
                    Smitty
                      I'm pretty new at this too, and started using the Olson 2/0 blades for the first time today. Pretty amazing accuracy. I haven't tried the gears yet - please let me know how it goes - one beginner to another.
                      J
                      Scrolling with a Dewalt 788 in a 50 degree workshop.
                        I would suggest you try different blades and find the one that's right for you.
                        personally I only use spiral blades and would'nt give them up for anything else.I used strait blades on the rings for the Circle of lights only because I ran out of spirals lol.
                        Jerry
                        Don't worry be scrolling
